Сохраненки
Благодарил (а): 1214 раз
Re: Сохраненки
Corsair "Version Number"
Corsair sticks identify the IC with a 'version number' on the label such as "ver 4.31" - props to them for this as it helps even less knowledgeable users to match kits when adding more sticks retroactively. The DDR4 numbers aren't officially documented, but they follow the same pattern as DDR3.
The numbers take the for "ver X.YZ" where;
* X is IC maker - 3 for Micron, 4 for Samsung, 5 for Hynix, presumably 8 for Nanya as with DDR3
* Y seems to be capacity per rank - 1 for 2GB, 2 for 4GB, 3 for 8GB. Usually this translates directly to IC density (8GB/rank = 8Gbit), but ver 4.14 which uses half as many double width "x16" 4Gbit chips is a special case.
* Z is revision, usually starting from A=0 and usually counting up one letter per increment. Hynix's first revisions are lettered "M" which is numbered as X.Y9, samsung now do this too and it will proesumably be the same.
The known and possible version numbers are as follows;
Version Vendor IC Confirmation?
3.20 Micron 4Gbit Rev.A Presumed
3.21 Micron 4Gbit Rev.B Confirmed
3.22 Micron 4Gbit Rev.E* Speculated
3.22 Micron 4Gbit Rev.F* Confirmed
3.31 Micron 8Gbit Rev.B Confirmed
3.33 Micron 8Gbit Rev.D Presumed
3.34 Micron 8Gbit Rev.E Speculated
4.14 Samsung 4Gbit D-die (4x16) Confirmed
4.23 Samsung 4Gbit D-die Confirmed
4.24 Samsung 4Gbit E-die Confirmed
4.31 Samsung 8Gbit B-die Confirmed
4.49 Samsung 16Gbit M-die Speculated
4.40 Samsung 16Gbit A-die Speculated
5.29 Hynix 4Gbit MFR Confirmed
5.20 Hynix 4Gbit AFR Confirmed
5.21 Hynix 4Gbit BJR Speculated
5.39 Hynix 8Gbit MFR Confirmed
5.30 Hynix 8Gbit AFR Presumed
5.31 Hynix 8Gbit "BFR"??? Speculated
5.32 Hynix 8Gbit CJR Presumed
8.20** Nanya 4Gbit Rev.A Speculated
8.30** Nanya 8Gbit Rev.A Speculated
*Rev.F is confirmed to come in ver3.22 sticks, but that doesn't leave a gap for Rev.E. It's wildly guessed that they may both appear under 3.22.
**It's unknown if Corsair even use Nanya for DDR4 but the version number it would likely be if they did is included for completeness
Re: Сохраненки
Re: Сохраненки
Андроид-компоненты:
http://developer.alexanderklimov.ru/and ... xtview.php
Отображение текста в Андроид:
https://habr.com/ru/company/redmadrobot/blog/461787/
Чат на андроид самопал:
https://www.cyberforum.ru/android-dev/t ... 33758.html
LAMW-потоки:
https://forum.lazarus.freepascal.org/in ... ic=41523.0
Queue и Synchronize:
https://www.sql.ru/forum/1327047-1/v-ka ... read-queue
Многопоточные программы в Delphi изнутри:
http://www.interface.ru/home.asp?artId=20679
PostMessage:
http://digital-flame.ru/2016/02/08/delp ... ie-probyi/
Re: Сохраненки
Главный поток приложения, «поток пользовательского интерфейса (UI thread)» в Android
https://habr.com/ru/post/142256/
Re: Сохраненки
Re: Сохраненки
Размеры видеокарты 3080 Founders Edition: 285 x 112 x 2 слота
GeForce RTX™ 2080 Ti GamingPro OC: 292 x 112 x 58 mm
GeForce RTX™ 3080 GamingPro: 294 x 112 x 60 mm
GeForce RTX™ 3080 GamingPro OC: 294 x 112 x 60 mm
GeForce RTX™ 3080 VENTUS 3X 10G OC 305 x 120 x 57 mm
Re: Сохраненки
Эффект звуковой сигнализации при старте заметен с видеокартами на базе графических процессоров NVIDIA 30xx серии с некоторыми моделями системных плат, в частности, на чипсетах Intel Z370 и Z390, звуковая индикация может быть связана с инициализацией видеокарт с PCIe 4.0 с системными платами с поддержкой PCIe 3.0, так как эффект заметен с разными моделями видеокарт на базе графических процессоров NVIDIA 30xx серии с разными моделями системных плат и с некоторыми моделями системных плат на чипсете AMD X570 при переключении режима интерфейса в настройках BIOS системной платы, в некоторых конфигурациях на заметность эффекта может оказывать влияние настройка CSM в настройках BIOS системной платы, поэтому можете проверить влияние соответствующей настройки, эффект не влияет на корректность функционирования конфигурации и исправность видеокарты и системной платы, также можете уточнить дополнительную информацию в поддержке производителя системной платы, вполне возможно, например, обновление BIOS системной платы для исправления соответствующего эффекта.
Для видеокарт на базе графических процессоров NVIDIA 30xx серии выпущены обновления BIOS, в обновлениях BIOS добавлена оптимизация совместимости с некоторыми моделями системных плат, в частности, исправления дополнительной звуковой сигнализации при загрузке при использовании видеокарт на базе графических процессоров NVIDIA 30xx серии с PCIe 4.0 с системными платами с PCIe 3.0, программа для автоматического обновления BIOS доступна в разделах загрузки моделей на официальном сайте.
Re: Сохраненки
Зеркала сайта:
https://zen.yandex.ru/media/rucenter/5- ... 1bda3eec8c
https://qna.habr.com/q/8749
Чтобы избежать автоматического выбора главного зеркала в дальнейшем, убедитесь, что страницы всех неглавных зеркал выполняют редирект на соответствующие страницы желаемого главного зеркала. Подробнее тут: https://webmaster.yandex.ru/blog/izmene ... -zerkalami
IDA:
https://habr.com/ru/company/inforion/blog/493416/
